May I know what the problem is? My rhino is version 6 and is a trial version.
Another thing I have encountered is I want to export a rhino model to revit and I save the file as “ACIS”, but then a prompt popped out and said “meshes cannot be exported to ACIS SAT files and will be skipped”. I have totally no idea what is going on.
I am greatly appreciated if anyone can help me figure this out. Thank you!!!
Are you trying to save to a network or locally to a hard drive? Does it happen with any file or just this one? What version of Rhino are you running?
That’s fairly clear - the object(s) you are trying to export are meshes and the file format SAT does not support them. You will need to use a different format that supports meshes, like .obj.
Thanks for your response!
Hi, I am trying to save locally to hard drive and this is my first time exporting from rhino to revit. I am currently using version 6 of Rhino and it is a trial version.
