Failed to save file
Just got this message trying to save.
Command: _Delete
Failed to save Rhino 6 file E:\AutoSectionCPlane.3dm.
The temporary file could not be renamed.
RM
I’ve also been having thgis every day or so recently, any ideas please?
This is the full message on the command line:
Failed to save Rhino 6 file T:\Dropbox\Projects\413_GC_HorseGuards\Model\20200617\All_On_Own_Coords_m_10.3dm.
The file is on a local drive, and SSD, which is also a Dropbox folder.
Is it related to using the SaveSmall command?
Thanks
I would try again in a minute - if dropbox is syncing as you save, this could easily happen.
Thanks Pascal, I did wait a few minutes then did a CTRL+S and it worked, I think I never had this before because I only used to sync Dropbox at tge startcsndxend if a session, but now ivhsve it running all the time.
Thsnks again,
Jonnie
