Hello, I’m trying to engrave a pattern into a ring, and all but ONE of the polysurfaces subtracted properly from the ring’s surface. Any ideas on what’s happening here?
As you can see in the screenshots below there is a mysterious hole in the solid ring’s surface that doesn’t appear when looking at the inside surface of the ring.
Hello - this is a problem, occasionally, with Flow/FlowAlongSrf that I’ve encountered a bit more than I like lately - the flowed surfaces are refit to a fairly dense structure and the control points tend to get jumbled - the surfaces that start off vertical end up folding on themselves at a microscopic level.
On this object, to get your work done, you can do the following and it should work:
Explode the flowed part.
Select all the side, or vertical surfaces
FitSrf to .001, DeleteInput=Yes. This will remove a lot of control points and return a thing that is, hopefully, slightly simpler and not folded.
Join and Join to the top and bottom surface.
Boolean operation.
I don’t know if there is anything we can do to make this more reliable for small objects like this but I’ll try to corner a developer and see what he thinks.
