I’m trying to export the selection into pdf but after few minutes of thinking in my PC the program collapses and close and nothing is save.
I have the 90 days evaluation license (Rhino 8) and I don´t know what is happening. I have tried all methods to try to save as pdf/png/tiff… but nothing seems to work.
I have tried a native Rhino file and other no, even in 2 differents PCs and I don´t know what is happeing.
I have tried also the print option but also failed.
I have updated Rhino into the latest version and updated the drivers of my graphic tarjet.
As Dan writes, if this is a file-specific issue on your machines, please post that file.
Apart from that, please run the Rhino SystemInfo command and copy-paste its output here.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-9-2025
Driver Version: 32.0.15.8157
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
I didn´t though on that but after try it, but, yes it works. I upload the file here to see if you can print this as png or not. I can not upload the Rhino version but a fbx one that can be open by Rhino. In fact the Rhino version I have for this file is the same after save as .3dm
I do have algo a native Rhino file but the same and is too big to upload here
I have a MSI gaming laptop with a gtx 1650 graphic, no so powerful, but enough for this. I don´t know why my pc is using the integrated graphic, instead the dedicated one
It is my understanding that the Rhino installer will choose the higher performance GPU, rather than the integrated power saving GPU. However, if it did not, you can specify that Rhino uses an alternate GPU here:
