Faces of objects rendering transparent when insde the object
I’m new to Rhino for mac. In windows, when you place the camera inside a rhino polysurface, the surfaces show as opaque. However, on mac they appear transparent. Let me show you what I mean:
With this object:
After going inside, walls show transparent:
After I explode the object, I get the desired result:
Is there any way to get this view settings without having to explode the polysurfaces?
Thanks!
Hi rosello - Rhino culls the backfaces of closed objects to avoid having to display more surfaces than needed (in most cases…). As far as I know you’ll need to have an opening someplace in order for both sides to be shaded.
