Facade following a curve
Hi everyone,
Hi! I’m trying to wrap a façade I’ve designed so that it curves around the circular part of a castle. Is there a quick way to do this in Rhino without having to redraw the entire façade?
My idea was to offset the castle’s circle by 0.
CROMWELL CASTLE FACADE.3dm (12.5 MB)
5 and then use a command to make the façade follow that curve - is there a command for this or a better method? In the screenshot below you can see my facade in white and then the curved castle tower.
I would do it using Grasshopper (if you don’t know yet how to use it, this might be a good occasion to start)
Here, I took one element, created two points at the start and end of it, then mapped it on points around a circle going around the tower
Castle.gh (14.8 KB)
Thank you so much this is so helpful and very good to know!
