Fabrication from Karamba3D
Hi all,
I am looking to export individual beams from Karamba3D “assemble model” to fabrication plugins such as OpenNest. Does anyone have a recommended workflow?
260309_ Hybrid structure mesh and analysis.gh (65.5 KB)
Thanks in advance!
Hi, there is no simple way to do this. You will need to use Grasshopper to generate surface geometry based on your beam meshes. One method would be to do an intersection of the beams with your reference surface for example and then to trim the surface, but it might not be 100% clean. There is most likely going to be some cleaning of the geometry.
Thanks so much, will try this out and see how it goes!
