Hello! I have a tiled surface that I would like to unroll to laser cut on 2 ply museum board.
How would I go about creating a laser cutting file so I keep all of these tiles in the correct place?
Thank you so much!
roof tiling.3dm (2.5 MB)
Thank you so much!
dear bri smith
a professional approach would be to use an automated workflow / a script to assign names and unroll or orient the elements, then use a nesting software for a cutting layout and engrave the names.
As a fast solution you can use _join
and _unjoinEdge
to cut the geometry into developable stripes.
to see the unjoined edges use _showedges
naked edges.
then
_unrollSrf explode=no
make sure to check that the normals point into the same and the desired direction, to not get a mirrored version.
_dir
you can also _project
or _pull
additional curves to identify the parts and unroll them as well.
hope that helps for a start.
best. tom.
Hi Tom!
I was hoping to go for the nesting approach with the engraved names! How would I got about finding/making a script to unroll and orient the elements?
Thank you so much
