I use AutoHotkey (AHK) to optimize my workflow in Rhino. To avoid key conflict issues that sometimes lock the canvas when holding Ctrl or Shift, I prefer mapping combination triggers—such as holding the Right Mouse Button + Number Key—to send Function keys (e.g., RButton & 1 sends {F10}).
Since 12 Function keys (F1–F12) are not enough for my macro list, I tried extending this setup to F13–F24 using Virtual Key Codes in AHK. However, Rhino does not seem to recognize inputs from F13 onward unless they are combined with standard modifiers like Ctrl or Shift.
Is there a built-in way or workaround to make Rhino native command shortcuts recognize virtual function keys above F12 (F13 through F24) without relying on modifier keys?
Give your macro an alias, and add your alias to the short key list as Alt + F key under Options > Keyboard Now us AHK to map your preferred mouse/keyboard combo to Alt + F key, instead of F13/F24
I read your previous message, thank you again! However, function keys don’t work with the Alt key—or rather, Rhino unfortunately doesn’t allow adding any shortcuts unless they include Ctrl. I’m not sure when they’ll implement this, but it’s definitely a feature I’ve been waiting for. I wish I could assign shortcuts like Shift + [Key] or Alt + [Key], similar to how it works in Blender.
Ah, you are right… I wouldn’t be surprised if this is simply a technical constraint of Rhino working with a command bar, unlike Blender. Alt and Shift are affecting text input.
