sorry I dont understand where is possible to find the help on line of the wip7 could you help me?
You can open online help by running Help
command in Rhino.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#information/welcome_to_rhinoceros.htm
You can also open help panel by running CommandHelp
F1 seems to work here to open the help (same link as above). Check in Options>Keyboard to see if the shortcut hasn’t been deleted…
thanks SERGIO ROSITAGIOIELLI
Thanks Sergio
Thanks but sorry I didn’t explain well the problem! my Rhino wip run in Italian, and I’d like to understand how function the Reflect command, so when I type Reflect on the search panel in the help doesn’t appear nothing, instead on you link no problem is it normal?
