how do you make a ½ sphere with a wall thickness of 0.16" ? cant find an extrude command that does it…
if the sphere is already halved and capped meaning solid you can use the command Shell and click on the front surface it will remove the cap creating a solid wall. otherwise you can use OffsetSrf with the options sharp and solid.
thanks, I just created a sphere from the Solid menu and cut it in half, thats how far I got. I don’t know if that means its solid or capped, or not…
it worked, thanks a lot, appreciate it
