I want to extrude all this sloping surfaces 1’-0" down from lowest point of individual surface, keeping bottom flat. Such that minimum height of extrusion is 1’-0".
Trial.3dm (3.4 MB)
Trial.3dm (3.4 MB)
Hi Pranav,
Your model has surfaces and curves in it. Assuming you just want to extrude the surfaces to create solids, one way would be to:
Extrude Surface to Boundary
from the Solid menu. Select the face as the boundary. This will create solids with a common base level.If you wanted to extrude the curves, you would need a slightly different approach:
HTH
Jeremy
Hi Jeremy,
Thanks for the solution, it worked!
