I am trying to make these extrusions solid to then do solid difference and make holes for bolts. Would you have any suggestions about how to do it or should I try sth else?
Cheers:)
Cheers:)
Cap Holes if you are extruding circles? Or make the circles a surface before extruding.
Easier to answer if you post a GH file.
Boundary Surface is the easiest way but I would use Cylinder and Cap Holes for this, then Move along the length axis into position if necessary.
