Hi, I have extruded the texture and the stamens of the flower but I can’t seem to understand why I can’t see the indentation. Please help! Susandaylily with dimension.3dm (6.8 MB)
When I shut off the layer with the extrusion of the texture it doesn’t leave an impression…
Hi Susan
Use curves to create extrudes (not closed). Then cut it with the necessary surfaces (blue in the file). The green curves are the references to create the lower cutting surface.
Simon
daylily with dimension.3dm (7.4 MB)
