I have created a polyline using curve tool. When I apply loft, it doesn’t select the entire stretch, but in splits. Is there any way to select the entire length
.Can you upload your file? Use the vertical arrow icon in the toolbar above where you type your post.
Zaha.3dm (10.9 MB)
How to loft this surface, there is some issue with selection. I watched a tutorial, tat guy can select the entire length of the curve. In my case it breaks.
The file you posted doesn’t have those curves - but a bunch of other stuff that is not relevant for this question.
When you start the loft command you could start SelChain
to select individual edges of those surfaces.
