Extruding with the cap toggle on fails on some values without reason
I’ve recently installed the new version of RhinoWIP. I am quite familiarised with grashopper 1, but I have no experience with the second version. I was trying to recreate a scipt I had on Grashopper1 and came across a problem when extruding a circle. I used the cap option. In some values it kept failing. It only drew the two caps an avoided the cylinder walls. Toggling the cap option on and then off seems to fix it but it is still a bit annoying. I can’t give you all a file to test it because the problem isn’t showing anymore.
Other thing I would like to know is if there is a way of naming the commands that have changed name in this version of grashopper as the ones in grashopper 1. An example would be Item index.
Let us know if you happen to run into this again.
no, this is not possible
You should be able to open your gh1 definitions in gh2, as it has a built-in converter.
