dcn7277
(Dillon Narcisse)
November 9, 2018, 5:32am
1
I’m making a grip for a hearing device and wanted to create a nice extruded contour all the way around. but it seems as if its only moving towards the x I want it to extrude frontwards
the file links are here:
exrtusion.gh (9.9 KB)
and the rhino file of the model:
Shared with Dropbox
Also here is an similar example of what I am trying to create…
Reo
(Reo)
November 9, 2018, 5:47am
2
Hi Dillon
I cannot help you if you should upload your file.
dcn7277
(Dillon Narcisse)
November 11, 2018, 2:52am
4
Hey, I updated the post with an example and the files, sorry if I didn’t set a duration on the post, my deadline is Sunday, November 11th
Reo
(Reo)
November 12, 2018, 1:54am
6
Hi dcn7277
I didn’t know why you used mesh so I created it with surface for extrude frontwards.
Please check uploaded file.
exrtusionV2.gh (10.0 KB)
dcn7277
(Dillon Narcisse)
November 12, 2018, 6:06am
7
Thank you, I seen what you did. Would I loft them together to make a surface? like those pictures I put in the post
dcn7277
(Dillon Narcisse)
November 14, 2018, 7:12pm
9
@Reo Thank you, I seen what you did. Would I loft them together to make a surface? like those pictures I put in the post
Adam_M
(Adam Mounsey)
November 14, 2018, 7:27pm
10
You could do something like this (see attached).
exrtusionV3.gh (11.7 KB)
dcn7277
(Dillon Narcisse)
November 14, 2018, 7:47pm
11
Thank you, that works, I was wondering how to connect it together as a surface where it shoes the indention of the extrusion …
I really want to create this type of texture that is below
Adam_M
(Adam Mounsey)
November 14, 2018, 8:01pm
13
There is a solid in there which has the indentations in it. Are you looking for an open polysurface instead of a solid?
dcn7277
(Dillon Narcisse)
November 14, 2018, 8:07pm
15
@Adam_M I’m sorry if I’m a bit bothersome I’m new to grasshopper
Adam_M
(Adam Mounsey)
November 14, 2018, 8:12pm
16
The component highlighted in the image above is the solid you are looking for…I think. If you Bake that object into Rhino, you will see the solid.
dcn7277
(Dillon Narcisse)
November 14, 2018, 8:18pm
17
@Adam_M I see it, but the extruded lines are not continuous up the body
Adam_M
(Adam Mounsey)
November 14, 2018, 8:43pm
18
You just have to try different approaches until you get to what you are looking for.
Here I changed the vector input for the Contour component to 60deg.
exrtusionV4.gh (12.5 KB)
dcn7277
(Dillon Narcisse)
November 14, 2018, 8:53pm
19
On my screen it docent shown that line continuity when I highlight that component
Adam_M
(Adam Mounsey)
November 14, 2018, 9:03pm
20
Strange. Maybe it is an issue with tolerance settings.
dcn7277
(Dillon Narcisse)
November 14, 2018, 9:04pm
21
how would I fix that? @Adam_M
dcn7277
(Dillon Narcisse)
November 15, 2018, 5:58am
22
@Adam_M I tried changing the tolerances didn’t change nothing is there anyway you can bake it for me and email it to me, it’s not working
