I have been using SubD for almost all my work these days, but there is a few things that are super wonky. I’ll address one today…
SubD extrude. When you have a planar SubD Surface, and you try to extrude it manually, or even with dimensions, it doesn’t seem to do anything that makes sense. It does not behave like the regular surface extrude.
With regular extrude, you extrude the surface, you use your curser to pull it where you want it to go, and it behaves.
With Extrude SubD, the controls are reversed, and they seem to respond only in the perpendicular direction of what you actually want to do.
If you are using the extrude subd command, you need to set the basis and the direction in order for the cursor to make sense.
in your case setting the basis to WCS and setting the direction to x should allow you to enter a numerical values that extrude to the right positive number values, or left for negative values.
For a planar SubD that you want to extrude along its normal (which looks like what you want in your video), you could also choose _ExtrudeSubD _Basis=_UVN _Direction=_N; this way it always extrudes in the “correct” direction whatever the orientation of the SubD.
I have been using SubD since it was introduced, and it’s amazing. This was just such a wonky default I had to bring it up, as it was behaving so differently than the Nurbs extrude command.
It wasn’t a deal breaker, as I knew what the output would be when I had my numerical values in place. It was just the UI made me scratch my head.
On a side note- It would be really nice to see extrude both sides implemented in ExtrudeSubD
@perrasjewellery Are you sure you didn’t run the ExtrudeSrf command by mistake? As far as I know ExtrudeSubD hasn’t changed in Rhino 8 recently, and I can’t see a “both side” or “solid” option here for it.
