I just noticed that the gumball can now extrude points into lines.
That calls for a long wished for ExtrudePt command.
Or better: a general extrude command catching points lines surfaces polysurfaces meshes and mesh faces…
-Willem
-Willem
Great!
Extruding points was added in the last WIP release.
The both-sides option works too.
Hi John,
I’m not sure if I’m missing this, but how does one extrude points in the latest rhino 7 (without the gumball)?
-Jeremy
Use the Line
command and for the start of the line just snap to the point.
– Dale
Hi Dale, thanks for the reply.
I suppose I was thinking that if I had many points and needed to extrude them a specific distance in a custom direction (e.g., like you can with ExtrudeCrv). I think the workaround could be to create a custom Cplane and then use the gumball extrude.
-Jeremy
