Or I changed some kind of setting I’m not aware off…
I don’t know since when this has changed and I don’t see a reason why it would, but when I try to use ExtrudeCrv and extrude to a certain point it projects my point to a random plane? It seems to be a plane where the curve lies on. This is Rhino V6.21
I know project is turned on, but then it would project to the cplane and not an invisible plane which it’s doing now?
This is in Rhino V5, which is the behaviour I would expect:
Hello - is Planar set in V6? (Status bar setting)
Yep, that’s it! Do you reckon Planar should be ignored when extruding a curve?
Hello - yep, that seems like a good idea. I’ll add it to the heap.
https://mcneel.myjetbrains.com/youtrack/issue/RH-56459
