Extrude tapered creates duplicate surfaces
To repeat this bug, use the attached file.
Select the curve
Run ExtrudeCrvTapered
Check Solid=yes
Set draft angle to 3
Click on Direction and select any direction other than the default
Extrude 15mm
Select the result and explode it
Click on any surface and you’ll see there are 2 where there should be 1
Version 8.8.24138.16021
extrudetapered bug.3dm (42.6 KB)
Hi Peter - got that, thanks.
RH-82091 ExtrudeCrvtapered - too many faces
