Is there a simple way to extrude a certain profile along a curve? I know Sweep1 is supposed to do the job (found this on the forum), but I first have to orient the profile correctly along the curve, and then I need to make sure that it’s exactly at the end of the curve otherwise it will only start from the position of the profile. And then It always ask me to indicate the ‘seam’, which I don’t really understand (but also doesn’t seem to have any effect whatever I click).
Is there no easier way to extrude a planar profile concentric, always perpendicular along a curve?
I found the OrientOnCrv function to orient the profile correctly, but I just can’t get it to orient it correctly It is never perpendicular even though my curve is perfectly planar, so It shouldn’t be so hard to understand in what direction I want the profile to be. Still I’ve been struggling with it for more than 2 hours, any help much appreciated!
Hello - the plane in which the curve to be oriented is selected is the base plane for the Perpendicular option in OrientOnCrv, not the curve plane. In your image, if you select the circle in that viewport and set the basepoint, then the Perpendicular option should orient the curve so that the plane of the circle is perp to the target curve.
Okay the perpendicular option in the orient on curve function did the trick (although for some reason it places the profile perpendicular at some distance from where I click on the curve).
To perform the sweep1 function it asks me to ‘drag the seam point to adjust’ is this just the point where my circular profile has its start and ending?
I would like the profile to be extruded for the whole curve and not just starting from where I put it on the curve, is there any way of doing this?
Thanks Wim, I completely understand it know. I just may not forget to click the ‘perpendicular’ option and to snap it to the end. Your help is very much appreciated!
