First run SelSelfIntersectingCrv to find the curve(s) that are self-intersecting, and then IntersectSelf to find the location(s) on those curves. You’d want to make sure they are fine while they are still planar, unlike in your file.
This is a site that vectorizes things? Usefull.
I won’t close the thread because I wanted to learn how to correct this kind of issue in-rhino, but thank you.
if you flatten it and curve boolean the curve. to clean it up- then you can extrude it.
but… this curve is really messy. I’d rebuild it at the very least, or redraw it from scratch ideally. this curve will not pass Cartier’s style requirements if you are doing any work for them directly.
To see the erros of the Curve, Wim sent a few commands to solve that.
To bypass the issue, Dale sent a plug-in
To solve it using raw Rhino, Kyle recommended a redraw.
I’d like to thank the three of them for every part of the solution.
It helped out a lot.
