Extrude a series of object with a variable height
I have a serie of squares like this:
I want each square to have a different height, as noted
how could I archive this?
I would first make sure the squares are sorted the very same way their height should increment
then I would create a Serie of numbers that starts from 1 and has as many items as the number of squares (Serie + List Length maybe)
then I would extrude each squares in Z direction by the amount of its respective value from the Serie component
for a solution with actual components I guess you’ll have to post your gh file
Here’s the gh file…
I don’t get what would you use to deconstruct the surface array to singular objects, and then extrude each one with the correct list
test array.gh (11.5 KB)
for a List of 100 squared surfaces we generate a list of 100 extrusion heights starting from 1 up to 100, then extrude each Srf by its respective value
test array_Re.gh (10.5 KB)
