I am trying to find the common edge of two touching, neighboring surfaces. More specifically, I want to identify that, for example, curve 3 on surface 1 is “the same” as curve 1 on surface 2. This also needs to be scalable, so I can use it for an entire structure. See attached image.
Thank you! I realize that what I was looking for is a bit more complicated than I initially thought - I will have to map the information I need back and forth - but this takes me a long way.
