Hello Everyone, I have a tree and I want to extract the middle element (which is a middle point in a coordinate system). From that tree, I used the average to find the average of each branch. I don’t have a specific number of branches so they might vary from one system to another. For simplicity, I have here three branches.
I tried to place a panel in the mask of the Split Tree component. I tried multiple masks and I also tried to use expression component to specify the middle element but it wasn’t successful. Could you please assist me with this? Can I place a variable in the mask? Thank you so much.
Hi magicteddy, thanks a lot! But I want to remove this element from the whole tree that’s why I am using split tree component. In a way this element will go to the positive part and the other elements will go to the negative part. Is there a way I can combine both?
Thank you Antoine Maes! The problem is that when I place this path in the split tree component, I will retrieve more than one element since this path contains more than one element. I want to remove only this element which is the middle or average point and keep the others!
Maybe the point nearest the average point? (minimum distance) But yeah, the definition is inadequate and with no GH / geometry provided so it’s a guessing game.
