I am relatively new in Rhino and grasshopper, so I apologise in advance if my question is silly or if it has been answered multiple times in the past.
I’ve generated a simple, cylindrical geometry which I would like to import into a finite element analysis software in order to generate a mesh. Ideally, I’d like to generate a uniform mesh of equally spaced points.To extract the generated geometry, I used the ‘bake’ button which converted the surface (generated using loft) into different components. Although in Rhino the resulting components seem to be symmetric and the generated grid of lines is uniform, however when I import the model in the FE software, the mesh looks like in the picture attached. Any idea why is this happening? I’ve also provided the grasshopper script. Any help will be appreciated. Thanks.
