Hi all, trying to figure out and fix why I can’t perform the same operations on a surface extracted from a BREP as I can for one I draw directly as a BREP. What is missing? The top script works, the bottom doesn’t.Extract and Divide Surfaces.gh (13.0 KB)
That’s probably because you used Split Tree, so the “P” output would probably contain some Null values which is the component’s nature by design.
Hence, it would be better to use Clean Treeafterward, or just use List Item(with index no. 1 in this case…)instead of using Split Tree.
thanks, still learning commands and tools, thanks for the List Item!
