Extract softedge mesh
Is there a way to extract the soft edge mesh?
Thanks,
Rafa
Hi Rafa - ExtractRenderMesh should get the softened mesh.
It doesn’t work. Maybe something is changed. But the command _ExtractPipedCurve doe’s the job.
Hi Micha - I just tried it here and it does seem to work - can you send me an example of it’s not working (ExtractRenderMesh not getting the softened mesh)
Softened mesh.3dm (87.3 KB)
Hi Pascal,
here a model where I can’t extract the mesh. I select the curve with
enabled piping and start _extractrendermesh -> Rhino tells me: “Select
surfaces, polysurfaces, meshes, extrusions and block instances:”. I
don’t know why but the piped curve can’t be selected.
-Micha
Rhino pipe extracting.3dm (871 KB)
Ah, ok, for a ‘piped’ curve, ExtractPipedCurve is the thing. I suppose it should be part of ExtractRenderMesh but it is not, so far…
Sorry, I mixed the topics. I was looking for a extraction command and discourse shows me this topic.
But it could be nice if extract render mesh could do the job. Seldom needed it’s not easy to found. Please create a ticket for:
  • _ExtractPipedCurve could be placed at the RMB of the curve piping button
  • _extracRenderMesh could be supported too
-Micha
