Extract flattened mean curvature analysis image
Hi, is there a way to extract the mean curvature analysis colored map as a flattened image? I am able to save it from front/ top etc, but I need it as a flattened image, any suggestions?
Hi Mohannad - it depends… if the shape is not too curved, with the analysis mode turned on, ExtractAnalysisMesh (this will capture the vertex colors) then Squish the resulting mesh - you can see the curvature map in shaded modes.
That’s exactly what I was looking for! Thanks a lot Pascal!
Hi @mohannad
You may also try ApplyMesh and map the curvature mesh for example onto a rectangular planar surface.
Jess
