Extract block members - feature request
It would be great if you could select and extract elements from blocks
The current trick is -
Run BlockEdit
Pick the element(s) you want to extract
Click OK to close the block editor
Hit Undo once
The interesting thing here is that the Undo undoes the removal of the element(s) from the block - so it stays like it was before editing - but it leaves behind a copy of the extracted (removed) elements in the file as discreet geometry… :grinning:
Thank you, but it wont work with DWGs - you can’t blockedit them. Exploding can be very slow with larger dwgs as well
