Extra Column to the 'Layouts' tab
It would be great if the Layouts Tab could have an extra column between the Layout and Size columns for ‘Drawing Title’. If this were possible, maybe we could print to pdf and the pdf file name would have a drawing number and drawing title… It could work a bit like the sheetset manager in AutoCAD maybe.
Perhaps you could use fields so it can link to the drawing sheet if you have the drawing title as a field in the sheet.
What does Mcneel think?
Thanks,
Andrew
Hi Andrew -
I’ve added this thread to RH-38644 Layout UI and workflow wishes
