The shift keys on my external USB keyboard ceased working today after upgrade to Version 7 (7.19.22165.13002, 2022-06-14). Is it possible that these events are related?
Not likely.
I use a USB keyboard and have not run into this.
I do get wonky behavior when it needs to be charged up again.
Assuming it’s fully charged, I’d be inclined to reset the Rhino Preferences file.
https://wiki.mcneel.com/rhino/mac/resetprefs
Any luck?
Hi John,
The problem was the keyboard, itself, which I have now changed. I don’t understand why keyboards fail like this. Key failure is usually put down to a worn contact but in this case both left and right Shift keys failed and I almost never use the latter.
are you using an apple keyboard or a 3rd party?
The problem occurred with an APPLE MB110Z/B USB keyboard. I have changed it for an A1843 (Bluetooth).
did it fix the problem?
Yes.
