Hello friends
I try to produce an extension of points with a repulsion point(attractive point) but unfortunately, I fail.
According to the picture, does anyone have a solution to produce this point extension so that only the points under a certain radius are repelled?
thanksssssssssssss
Dear friend @HS_Kim
I want to install panels on these points that open and close with that repulsion point as shown in the image. I think it is hard work. Of course, I did some of it, but unfortunately it is wrong.
QQQQQQQQ.gh (16.4 KB)
Tip: @HS_Kim gave you an answer that you can modify and plug into the rotation of your surfaces in your script. It’s the same principle as moving the points.
