ExtendSrf Different Langths DC01.3dm (2.0 MB)
Version 8 SR30
(8.30.26090.13001, 2026-03-31)
Simple single span, untrimmed symmetric rational surface. Degrees 2 x 1.
ExtendSrf opposite edges by the surface by the same amount and the extensions are different lengths. Because the surface is untrimmed and symmetric I expect the extension lengths to be the same. (Results are the same with Merge=No or Merge=Yes)
This looks like a bug.
Command line history:
Command: ExtendSrf
Select an edge to extend ( Type=Smooth Merge=Yes ): Merge=No
Select an edge to extend ( Type=Smooth Merge=No )
Extension point <2.000> ( SetBasePoint Type=Smooth Merge=No )
Command: ExtendSrf
Command: ExtendSrf
Updated (Credit to @sjb for identifying the problem as dependent on surface location.)
The extension lengths of rational surfaces created by ExtendSrf is dependent on the location of the surface. Non-rational surfaces work correctly. This bug identified a long time ago. A YT item was created over 8 years ago and assigned to Greg Arden, who has since retired. It needs to be assigned to someone else with priority. https://mcneel.myjetbrains.com/youtrack/issue/RH-41887
The results of ExtendSrf should be totally independent of the surface location. In addition if opposite edges of a symmetric surface are extended with the same “extension point” the resulting extension lengths should be the same.
Example file of symmetric surface in rational and non-rational forms in multiple locations.
ExtendSrf Bug DC10.3dm (2.1 MB)
Rational surfaces are blue, non-rational surfaces are green:
