Hi all - ExtendSrf has changed, for the next WIP - you can now click and drag edges interactively, in either direction (i.e. extend or shrink back a surface on trimmed and untrimmed edges). Please give it a try and report cases that do not work as you expect.
The windows select thing is cool but I think it could be a double edged sword, especially if you don’t expect it! Also it doesn’t seem to work with a crossing window.
OK, that’s a bit clearer. I was using points for redistribution so didn’t see that it was just the axis of the spacing that changes. I was expecting that the objects would reorient along the vector of the direction.
A bit confusing that the order of the objects changes as well, (right side of the bottom example).
Thanks,
Nick
Right, but the edges, in that odd angle axis, are in fact not in the same order as they are in the X axis - I think it is doing the right thing. But that custom axis thing may turn out to be too confusing as default input - it may need to be an option.
I joined two identical rectangular planar surfaces then tried to extend one of the co-linear edges; that didn’t work. I can extend one of the un-joined edges, so that’s good.
Right. In general, ExtendSrf allows you to select a naked edge (in a surface or polysurface, trimmed or not). For a polysurface, both side edges (the ones to be stretched) should be naked too. However, I do see some inconsistencies. I will investigate.
I have several trimmed surfaces that will not extend. They will collapse, but not extend.
I get “Collision detected. Nothing done”.
Some surfaces will extend past the original edge if collapsed first, others won’t.
All will extend if untrimmed first.
Am I using the command properly?
v5 would extend a surface (even crazily) or return “invalid extension” if it couldn’t extend.
This email is confidential and intended solely for the use of the individual to whom it is addressed. If you are not the intended recipient, be advised that you have received this email in error and that any use, dissemination, forwarding, printing, or copying of this email is strictly prohibited. If you have received this email in error please return the message to the sender by replying to it and then delete the message from your computer.
No responsibility is accepted for any virus or defect that might arise from opening this e-mail or attachments, whether or not it has been checked by anti-virus software
Rajaa great work for this command! More functional and powerful than the past (it would be perfect if you could extend multiple edges simultaneously …).
