ExtendDynamic only let you shorten curves
Hi All,
In the last V9 betas I’m having an issue with _ExtendDynamic, it doesn’t happen in V8.
When I want to extend a curve I can’t do it, the command just let me shorten but not extend.
Is there any setting I’m not understanding?
@laborda can you send an example file and _SystemInfo?
In a quick test I could not reproduce what you’re describing
Thanks @Gijs this is one of the cases.
If you try to extend the long edges or the extracted curves from the long edges, you can’t do it.
Rhino 9 SR0 2026-7-14 (Rhino 9 BETA, 9.0.26195.12303, Git hash:master @ e65c4e97d90a610a755e1fa38d13856483719a8c)
License type: Educational, build 2026-07-14
License details: Cloud Zoo
Expires on: 2026-08-28
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using OpenGL
Primary display: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 4-15-2026 (M-D-Y). OpenGL(4.6.0 NVIDIA 582.53)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-15-2026
Driver Version: 32.0.15.8253
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 7\Plug-ins\DATAKIT\Rhino7_Import_x64.rhp “Datakit_to_rhino7”
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V9\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\joaco\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot11RhinoPlugin (55124e8a-aa81-4be8-8e12-9f452c473970)\1.0.0.0\KeyShot11RhinoPlugin\Rhino 7\KeyShot11RhinoPlugin.rhp “KeyShot11RhinoPlugin” 1.0.0.0
D:\Programas\3D\HDR Light Studio 7.4 2021\HDR Light Studio-connections\HDR Light Studio CONNECTIONS\RHINO\Rhino_7_Win_2019.0624\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26195.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
ExtendDynamic_260721.3dm (71.6 KB)
thanks @laborda
RH-97110 ExtendDynamic doesn’t extend
RH-97110 is fixed in Rhino BETA
