V5
I wish to extend a curve not as a straight line but continuing its curvature.
I expect it to be ExtendCurve.
I type Extend expecting to see ExtendCurve in the dropdown but its not there.
googling sees ExtendCurve. so I am right.
I type Extend again expecting to see ExtendCurve but its still not there.
However if I type fully that command it then exists !
So another reason to stay with V5 ?
I am using it, so what command instead extends a curvy line as a curvy line continuing the nature of the curve ?
@jeremy5 I assume you meant “Natural”, not “Normal”. The available Type= options in Extend for both V5 and V8 are Natural, Line, Arc and Smooth.
Can you provide the curve in your example.
I don’t see any differences with I use Extend on the same curve for the same length at both ends in V5 and V9 Beta, with both Type=Natural and Type=Smooth. ExtendTest.3dm (35.9 KB)
ExtendCurve was a test command in Rhino 5, which is why it never showed up in autocomplete. Starting with Rhino 6, it was replaced by ExtendDynamic. That’s what the “Extend curve” toolbar button runs.
ExtendDynamic and Extend share the same code. ExtendDynamic just skips the boundary prompt and lets you drag to a length. To continue a curve’s shape, use Type=Natural or Type=Smooth in either command. As David found, the results match Rhino 5.
I’m sorry but I didn’t keep the curve; and yes, Natural, not Normal - good pick up.
But I see the Extend behaviour being totally different in R5. With Natural or Smooth options the extension ends up at the cursor position, regardless of how nice an extension it makes. Here with your curve:
Whereas ExtendCurve did what Extend now does in R8 and R9.
@jeremy5 It’s more complicated than Extend in V5 behavior is different than in V6 and later.
Extend in different versions behaves the same if the extension length is specified or an extension boundary is used. (I specified an extension length in my example above.)
Extend with “dynamic extend” and Natural or Smooth in V6 and later can function differently than in V5, but they can also function the same. It depends on whether the ToPoint option is selected after the curve to be extended is selected.
In V5 Extend with dynamic extend and Natural or Smooth the cursor can be moved anywhere and the extended curve ends at the cursor position.
In V6 and later with dynamic extend and Natural or Smooth and the cursor is constrained to the same curve that would be created if an extension length was specified or a boundary was selected. This is the same as the V5 ExtendCurve test command. UNLESS
After extending the curve to extend the ToPoint option is selected. Then the cursor can be moved anywhere and the extended curve will end at the cursor. This is the same as the V5 Extend with dynamic extend.
