there is rs.PointClosestObject() which you could use and test against the endpoint(s) of your connecting item. It would handle the distance measuring part for you. Alternatively, if only one object is intersecting the “connecting item” you could use rs.CurveCurveIntersection() to find the one which intersects…
[(1, <Rhino.Geometry.Point3d object at 0x0000000000000063 [-15.6338448046463,19.4051846091331,0]>, <Rhino.Geometry.Point3d object at 0x0000000000000064 [-15.6338448046463,19.4051846091331,0]>, <Rhino.Geometry.Point3d object at 0x0000000000000065 [-15.6338448046463,19.4051846091331,0]>, <Rhino.Geometry.Point3d object at 0x0000000000000066 [-15.6338448046463,19.4051846091331,0]>, 43.405189045484356, 43.405189045484356, 11.418795844012088, 11.418795844012088)]
However the description says two-dimensional list which should be [[1,2,3],[4,5,6]] however the result is like [(1,2,3)]. A list in in parenthesis inside square brackets and not square brackets in a square bracket. Is it the right syntax? I can make a 2d loop but not able to query elements sequentially [0][1].
all ist right, it’s just how Rhino prints a list it if you print the whole list as a single variable. Try iterating over the list, you can query the elements sequentially by using indices too:
import Rhino
# 3 points
pt1 = Rhino.Geometry.Point3d(1,2,3)
pt2 = Rhino.Geometry.Point3d(4,5,6)
pt3 = Rhino.Geometry.Point3d(7,8,0)
# a list of 3 points
pts = [pt1, pt2, pt3]
# access by index (second point, Z-coordinate)
print pts[1][2]
and for the result of rs.CurveCurveIntersection note what the helpfile states. It does not print only points, but also the event types. The first number you have in your list from above is not a point but the intersection event type. The example shown here might help to understand the return values…
_
c.
check if intSect is not None before printing intSect[0][1]. Then check if you’re accessing items which do not exist. Ps. It would be helpful if you post example code and geometry to test what you’re doing.
