when i use extend wall inside a block (for a typical floor) it cancels the Extention
Hello - what command are you running? In general, you can’t modify the contents of a single block instance, you need to use BlockEdit
and the change will affect all instances.
I do not quite understand what you mean, I enter the block by block edit and as soon as I save the change and exit the block it is canceled
Hi @11170, the wall extension inside a Block should work. Can you attach the 3dm file and indicate which block you are trying to edit?
Thanks for the file. I could reproduce the error. I’ll get back to you when we fix it.
Something you could to to workaround this is to explode the block, extend the wall, and generate a new block afterwards.
