Hello!
I have a problem which needs expert advice, please help.
I have a surface generated by a loft curves. I need to :
- Expend the faces of the breeb generated by loft curves along the direction of the line.
- Generate a volume with the extendet loft surface (the caps are perpendicular to the direction of expension line)
- trim the extendet volume with the box and select one of the parts optain from division.
I tried to use the script for extend face but it doesnt considers the intersection between faces … thats the bigest problem …Any suggestions are apreciated … Thank you!
extend volume,trim volume.gh (12.6 KB)
