If I extend this surface I get inaccurate results. File attached. Thanks for checking.
Extend surface bug.3dm (56.5 KB)
The surface is invalid (bad object). Just delete it and make a new planar surface from the outline curve.
Thanks.
Hi @Helvetosaur,
Do you know if there’s any way to check surfaces as soon as they get created? Because I’m bumping on too many bad surfaces and things get confusing. Thanks.
Hi - bad objects should be flagged when they are created. You can run the CheckNewObjects
command to make sure that this function is turned on.
Thanks, Check was set to No
