Extend still sucks
The extend command (with type=natural and Join=Merge) is very limited on this curve. But I can extend it again after extending as far as rhino will let me on the first go. Why can’t I just do it in one operation?
Similarly, I can’t extend this surface much in the long direction. It’s a pretty simple surface though and seems like it should extend better/more.
cant extend either.3dm (40.6 KB)
cant extend.3dm (35.9 KB)
thanks Peter, I’ll see if this can be tuned up
RH-94537 extend sucks (per user)
I’ll point this out: when it happens to me, I always notice that Rhinoceros 3D struggles to extend surfaces that were previously trimmed. I usually use Untrim or Refit.
Right after rebuilding, with control points active, Extend doesn’t work. Once I deselect, Extend works again. Is this unusual behavior?
extend for curves has been tuned up a bit in
Work In Progress
(9.0.26098.305, 2026-04-08)
Commercial
give it a go and let us know what you think
Extend is much better!
