ingemar
(Ingemar)
March 20, 2020, 9:28am
1
Variable x: Number
Variable y: Null
This is exactly as in GH Primer V3-3. Still paralyzed by “syntax error” message.
Now I use GH 1.0.0007. Maybe something has changed in this newer GH version? Any clue?
Ingemar
It would be good if you add a screenshot if not the gh file.
ingemar
(Ingemar)
March 20, 2020, 9:54am
3
Expression_syntax_error.gh (12.0 KB)
Hope you can find out. Thanks,
Ingemar
HS_Kim
March 20, 2020, 9:58am
4
Sounds like you are suffering from one of the most recurrent questions. Check the linked topics bellow.
Hey Guys! I´d appreciate a lot if you can help me out in kind of the same issue:
Well, It may be a certain way to write expressions for functions in grasshopper, although it seems to be that I don’t know the correct way. I´ve been trying quite a lot of different ways to compose a function with “x” variable and “x and y” variables, but any time I finished the function into the component it turns up a warning, which is not actually shown in the expression designer window. So what should be the pr…
[Evaluation%20error]
Hello all, I am newbie in grasshopper and start learning from a Book called AAD. I am practicing from the screenshots given in the book, The same recipe i am using, but it shows some evaluation error can someone please help me out with this. (please download attached image for understanding my problem)
Thanks.
04_solid_mapping_b_re.gh (16.6 KB)
lander
(CAD CAM CNC)
November 16, 2023, 6:47am
5
K, and I’m not seeing the solution other than “don’t use draw full names, it’s just there to trick you”:
It’s a known issue when you are running GH in “Draw Full Names” mode
Change input variable name from Variable x --> x, Variable y --> y.
So, why have the option? Or how to use said option?
