Expose Shapediver data outputs in Autodesk Forma
Is it possible to see the data outputs from my Shapediver file in Forma?
This is how it looks like in Shapediver, but in Forma I can’t find those outputs.
At the moment, data outputs are not exposed in Forma. In most cases (including your case), the data that interests you is already native to Forma objects. Once this data is exposed through the Forma SDK we can allow users to send these values as attributes of the geometry which would then be translated into Forma properties. I will let you know when we make progress about this topic.
