Hi! I am trying to export some blocks from rhino using python into .wrl format.
I know that I can supress the diaglog box in Rhino by doing -_Export and then I can enter my parameters through a script in python. What I am confused about though is that the parameters I can access through python are not the same as those I can access through the user interface.
Accessing the interface through python I can only access the parameters for .wrl exporting that you see in my script below but if you do the process out by hand on the user interface on the polygon mesh options dialog box, if you click “detailed controls” there is the option for simple planes. How can I access this “check box” from a python script like I access the other parameters.
Thank you!!
My script (which works to export the .wrl file) is as follows
# iterates through layers
# select all in current layer
rs.Command("-_SelAll ")
directory = 'C:\\Users\\Rebecca Napolitano\\Documents\\datafiles\\Romanbondingcourses\\2017_10_25_experiments\\'
filename = 'test'
filetype = '.wrl'
# make cmdstr, include layer if there are multiple layers
path = "\"" + directory + filename + filetype + "\""
cmdstr = "-_Export " + path
if filetype == ".wrl":
cmdstr += " Enter"
cmdstr += " Angle 0.0 AspectRatio 0.0 Distance 0.0 Density 0.0 Grid 0.0 "
cmdstr += " Enter "
#cmdstr += " Enter Enter"
# execute command
cmd = rs.Command(cmdstr)
if not(cmd):
success = False
rs.Command("-_SelNone")
Here are the options I can script:
Here is the parameter I need to access:
Hi @Rebecca_Napolitano,
its seems to be missing in the command options of the wrl export. One workaround would be to script the _Mesh
command first, select the resulting meshes and export them as wrl, then just delete the meshes. The _Mesh
command has the missing option:
_
c.
This worked! Thank you very much @clement !!
In case anyone else ever needs this, it is code that loops through your layers, meshes what is in there, grabs only the mesh, and exports it with its layer name to a file location as a .wrl file with simple planes.
layers = rs.LayerNames()
for layer in layers:
if layer != 'concrete':
# select layer
rs.Command("-_SelLayer " + layer)
rs.Command("-_Mesh DetailedOptions SimplePlane=Yes Enter")
directory = 'C:\\Users\\Rebecca Napolitano\\Documents\\datafiles\\Romanbondingcourses\\2017_10_26_experiments\\'
filename = 'test'
filetype = '.wrl'
if len(layers) > 1:
path = "\"" + directory + filename + "_" + layer + filetype + "\""
else:
rs.Command("-_SelNone ")
rs.Command("-_Invert ")
rs.Command("Hide Enter")
rs.Command("-_SelMesh ")
# execute command
if not(cmd):
success = False
rs.Command("-_SelNone" )
rs.Command("Show" )
good ! Note that you’ll need to enclose a layer name into quotes if you pass it to the command line. Otherwise, if the layer name has spaces in it, Rhino’s commandline will interpret that space as Enter. Eg. if you have two layers one is named “Concrete 1” and the other “Concrete” and you do this:
layer = "Concrete 1"
Rhino will try to select the objects on the layer named “Concrete” not “Concrete 1”. If you do it like this:
layer = chr(34) + "Concrete 1" + chr(34)
it will select the objects on layer “Concrete 1” because the layer is enclosed in quotes and interpreted as one word.
_
c.
