So today i got into work and came into a problem i had never faced before.
I regularly do technical drawings in rhino and then export them as .svg to assemble them in illustrator, in fact i had been doing this for the entire week, and it was the last thing i had been doing before turning off the PC the previous day.
Well today i try to do what i have always done and the .svg just saves blank.
no program i have tried to open it with seems to be able to pick up anything so im pretty sure its the exportation that’s not working properly. it appears just fine in the preview window, as you can see in the anexed photo, but afterwards just nothing shows even tho rhino says it’s saved successfuly.
Have tried to mess around with the position in export settings as well as centering it in rhino coordinates as i assumed it was just exporting my drawings outside of the display but nothing has worked.
Im running Rhinoceros Version 6 SR7 (6.7.18199.22081, 18/07/2018).
Thank you in advance for any ideas you might have on this cuz im coming completely empty handed.
- List item
