Exporting simple geometry as STL is creating insane amount of triangles
Hi Guys,
So I’m having a bit of a weird one here that i cant quite wrap my head around.
I have created these fairly simple shapes, but when i export as an STL, rhino creates an insane amount of triangles and a huge file.
I already found a work around by converting to mesh and then exporting as STL, but id like to know if any of you guys have a clue what is going on here?
Here is a sample of the file the file if you want to have a look yourself, maybe its my machine but that didnt seem very likely to me.
Polygon Test.3dm (939.1 KB)
Cheers in advance
I get a pretty reasonable result with these settings.
Hi Kyle
Thanks for the reply, that seems to have solved it. The settings my file was trying to export to are below.
So i was curious which one was causing the grief, so I went through and changed each individually to see when it changed. It was the Maximum Aspect Ratio that was causing it, changing that to 0 gave me the below result.
This was someone else’s file i was sorting out to print. Im guessing maybe they had changed their export options on the file or something because as soon as i opened a new file to export an STL, my settings were back to default.
Thanks for your help!
