Hi there,
I am not used to scripts so I have no idea if this request is even possible.
Following situation (see picture first to get better idea what I am writing):
I want to create 9999 numberplates going from 0001 till 9999.
Each number on the thousands, hundreds, tens and one digit is on a respective level/sublevel.
The idea is that a script starts at 0001, saves this variant as a dxf with the file name 0001.dxf.
Then switch off/on the respective sublevels and save all 9999 possibilities with the respective file name.
Does anyone here see a way to make this possible or is it too complex?
Yes this is certainly possible.
HOW many experience do you have with scripting?
I made a quick setup that might work already or you might need to tweak it.
Let me know what you think and report back
BE CAREFUL with directly testing all exports.
first test for a small range to make sure all works
import os
def reset_layers():
rs.CurrentLayer('Kreis')
for layer in rs.LayerNames():
rs.LayerVisible(layer, True)
layer_end = layer[-1]
if layer_end in ['0','1','2','3','4','5','6','7','8','9']:
rs.LayerVisible(layer,False)
def turn_layer_on(position_index, number):
positions = ['Duizendtallen','Honderdtallen', 'Tientallen', 'Enkeltallen']
full_layer = '{}::{}'.format(positions[position_index],number)
rs.LayerVisible(full_layer, True)
def export_visible(folder,dxf_name):
rs.UnselectAllObjects()
rs.SelectObjects(rs.NormalObjects())
dxf_file = os.path.join(folder,dxf_name+'.dxf')
rs.Command('_-Export {} _Enter'.format(dxf_file))
def export_badges():
folder = rs.BrowseForFolder('folder for export')
if not folder:
return
start = rs.GetInteger('start number')
if not start:
return
end = rs.GetInteger('last number')
if not end:
return
rs.EnableRedraw(False)
for N in range(start, end+1):
reset_layers()
text = '{:04d}'.format(N)
for i, character in enumerate(text):
turn_layer_on(i, character)
rs.Redraw()
export_visible(folder,text)
rs.EnableRedraw(True)
if __name__ == '__main__':
export_badges()
