Exporting Rhino to Cad the Revit with curves maintained
I need settings to Export from Rhino to Autocad dwg into lines that can be picked in revit. The curves become segmented. I want the lines as one whole curve that can be picked or projected in Revit.
I don’t have Revit here…
In Revit, can you export to DWG and import that DWG file back into Revit making sure that the curve is as you need it? If so, please post that DWG file here - perhaps this way we can find out what it needs.
Check your ACAD export options - you might see if you have curve tessellation activated (converts splines into polylines for export) - make sure arcs and splines are exported as such and not as polylines…
I am unable to attach the Rhino file. Is there a way to do so?
Drag and drop it into the message window, or use the upload button at the top of the window…
